Posted by Brownie 450 on June 08, 2009 at 13:50:22 from (216.51.158.172):
In Reply to: farmall c not running posted by Eric Phipps on June 08, 2009 at 11:37:25:
How is the wire from the switch up to the coil?? Also the switch itself?? When it starts to die next time, pull the choke out a bit to make sure fuel delivery isn't the problem. If it still dies, connect a jumper wire from the battery hot terminal to the coil primary terminal that comes from the switch. If the engine starts/ runs, look for a bad wire/ terminal/ switch. Something is not making the connection in the electrical department, & you have to isolate which area is causing trouble. These systems are not that complicated.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
