Re: farmall c not running
Posted by mkirsch on June 08, 2009 at 13:59:21 from (64.80.108.56):
In Reply to: farmall c not running posted by Eric Phipps on June 08, 2009 at 11:37:25:
There are two reasons for gas to run out of the carb:
1. The float is not set right or is sticking.
2. You're cranking for several minutes at a time with the choke closed.
Either way the engine is flooding and that's why it's hard to start.
Take the carb apart and start over. Don't get discouraged, happens to everyone. Took us four tries to get it right on my Super H.
When starting, quick blips of choke only. Do not hold the choke. Once it fires, feather the choke to keep it running.
When it stalls, does pulling the choke change how it runs? If so, you have a fuel problem. If not, it's usually ignition.
