Posted by SDE on June 08, 2009 at 14:56:37 from (72.160.220.164):
In Reply to: farmall c not running posted by Eric Phipps on June 08, 2009 at 11:37:25:
Do you have any gas filters in the line? Is there a brass screen in the gas line inlet of the carb.? Fuel flow. Allow a gallon of gas to run thru the carb drain and watch to see if it flows more slowly after the first pint. Maybe the float is making contact with the side of the fuel bowl.
After it dies, is the carb empty? Do you have spark after it dies?
I am sure others have asked these same questions, but I not current on your situation. SDE
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
