Re: transmission puzzle?
Posted by Janicholson on June 08, 2009 at 19:24:16 from (66.173.50.91):
In Reply to: transmission puzzle? posted by PeteInPA on June 08, 2009 at 16:10:54:
Put the PTO in gear, as well as the tractor in first, then rotate the PTO with a suitable tool (I like a bolt through the pin hole, and a big crescent wrench pushing on the bolt head) This will drive the tractor forward if the trans ans all is good. If it is the clutch (with it in Neutral) you should be able to see the system slip! JimN
