Re: IH 350 utility backhoe
Posted by Janicholson on June 08, 2009 at 20:16:37 from (66.173.50.91):
In Reply to: IH 350 utility backhoe posted by karl v on June 08, 2009 at 10:10:15:
If it starts well, it has OK compression on at least a few cylinders. While running is it an even regular misfire, or a irregular misfire. If regular, or the exhaust puffs smoke, crack the nuts on the fuel lines one at a time to bleed off the fuel pressure to one cylinder at a time. This can isolate a dead cylinder.
This engine is tough on the wallet to rebuild due to uncommon expensive parts. It is economical, and strong when correct. Bad injector patterns and pump can cause all these symptoms and are much cheaper than the rebuild it would need if low on compression. Good luck, I like 350UDs JimN
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
