Re: Cub Piston rings
Posted by El Toro on June 09, 2009 at 04:20:08 from (64.12.116.73):
In Reply to: Cub Piston rings posted by JFavor on June 08, 2009 at 19:05:41:
If it needs to be bored oversize you will need to buy new oversize pistons & rings. Your machine shop can get the new piston set & rings. Have the crankshaft measured for wear too as it may need to be ground undersize. Your machine shop can furnish the correct undersize bearings. Hal
PS: If they dipped your block to clean it make sure all the plugs were installed before you start the rebuild. Ask your shop about this since this will affect your oil pressure.
