Re: Farmall F-12 Cracked frame rail.
Posted by Dave Allgire on June 09, 2009 at 11:02:13 from (24.217.35.194):
In Reply to: Farmall F-12 Cracked frame rail. posted by Mark J F in Michigan on June 09, 2009 at 08:31:01:
Where on the frame rail is the crack? If it is at a stress point, you may need to install a gusset to keep it from happening again. Yes, it is steel so it can be welded. Your choice of rod should be OK.
