Re: Farmall Cub won't start..
Posted by Jeff B. on June 09, 2009 at 17:18:18 from (69.20.162.151):
In Reply to: Farmall Cub won't start.. posted by Gevan on June 09, 2009 at 17:07:57:
If you were running a 6v coil previously, whoever converted it probably put a ballast resistor in line to the coil to reduce 12v into 6v. Now that you have a 12v coil on it, you need to remove the resistor so your coil is being supplied 12v instead of 6. Right now you"re feeding 6v into a 12v coil and it probably doesn"t have enough poop to make a good spark.
