Re: 560 diesel pump
Posted by Gene- WI on June 09, 2009 at 17:39:15 from (204.120.20.2):
In Reply to: Re: 560 diesel pump posted by bornred on June 09, 2009 at 17:08:08:
I don't know what they're talking about, I used my 560 all winter to haul manure and sometimes it was 30 below and snowing and I didn't have any hyd part whatever that is, freeze up and cause the pump to break, generally what happens is the banjo fittings start leaking and the bolt gets tightened too much or the wrong copper washer gets installed and the bolt bottoms out against the shaft causing the pump to bind and breaks the shaft. As far as I know there isn't anything hyd. that the pump drives.
