Hold your hand over the throat of the carburetor and see if there's good suction on your hand while someone makes an attempt to start the tractor. If the suction is weak pour some engine oil on top of the pistons and crank over the engine a few times and reinstall the plugs. Then see if it start. You need good intake manifold vacuum to pull that fuel into the engine. Hal PS: Run a compression check on all the cylinders and compare the readings.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
