Re: Farmall Cub won't start..
Posted by Gevan on June 10, 2009 at 05:51:45 from (207.200.116.5):
In Reply to: Farmall Cub won't start.. posted by Gevan on June 09, 2009 at 17:07:57:
More specifics about when the problem started. With new 12V battery installed, but 6V coil, Cub started and ran fine for 6 hours. I received a crank and wanted to crank start it. It started fine with crank, and ran for about 2 minutes then abruptly stopped. I assumed out of gas - that's when I left the battery switch on and blew the 6V coil. Some of the suggestions don't seem to fit with an abrupt stop and then no firing at all.
After cleaning the carb, how do I know if gas is actually getting into cylinders? I get whitish smoke on cranking engine, but only rare occasional firing, sometimes when cranking stops a backfire...
Other ideas?
