Re: brake bands for a Farmall H Where to get them
Posted by Dave in CT on June 10, 2009 at 07:21:03 from (69.177.215.91):
In Reply to: brake bands for a Farmall H Where to get them posted by Brad in WI on June 09, 2009 at 18:52:01:
One detail that caught me when I replaced my H's bands was the cam unit was bent skewed. There are two triangular pieces of steel at either end in that cam and they should be aligned. If they are bent so one triangular plate is at a different angle than the other, your brake will probably be too loose - even with a new correct-length band. Just putting this in here so you can have a look at those before you reassemble.
