Re: 300 farmall hydraulics
Posted by Janicholson on June 10, 2009 at 10:00:14 from (199.17.6.22):
In Reply to: 300 farmall hydraulics posted by roscoa on June 10, 2009 at 08:01:46:
I would look for heat in the system. The pump can get so hot as to boil the fluid. If it gets extremely hot. something is putting a load on the pump. it might be a valve not centering, or a mis adjusted pressure control, or a single or dual action control (bottom end of each valve) that is not turned all the way. to the correct position.
If the system remains cool, an air leak into the intake side of the pump can cause foaming and non operation. Good luck, JimN
