Re: Farmall C Still no Music
Posted by ScottyHOMEy on June 10, 2009 at 13:44:43 from (70.105.245.97):
In Reply to: Farmall C Still no Music posted by Eric Phipps on June 10, 2009 at 11:47:33:
After reading the other comments, I'd also toss in a suggeation that you check your plug wires to make sure you've got them all hooked up in their proper order.
#1 is customarily at about 2 o'clock, but could be anywhere. Once you have the motor at TDC on the compression stroke on #1, and the rotor button lined up with the tower for the wire to #1, they should go clockwise, when viewed from the rear, 1,3,4,2.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
