Posted by IH fan on June 10, 2009 at 13:57:01 from (69.148.249.59):
In Reply to: I got my SC posted by KenB_Texas on June 09, 2009 at 21:59:51:
You don't say if the Super C has the fast hitch or not... most I have seen do have it.
The front mounted implements should be the same for C, SC, 200 and 230. Rear will of course be different from fast hitch or non-fast hitch. Some non FH implements may fit even if the tractor has FH, but most likely the FH will interfere. Mounted plows were available for either, but disks I believe were only available for FH. I plowed, disked,cultivated and mowed many acres with FH mounted equipment and thought all worked pretty well. Only drawback I noticed was no draft control with the plow made it less accommodating, but not all that bad. Dad had a non-FH mounted plow for a C and thought it did a better job than the FH version... I never used it, so have no opinion. One very nice option with fast hitch is that the plow and disk can be adjusted from the seat with the touch control, and pins can be relocated to allow for floating.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
