Re: Farmall C Still no Music
Posted by Janicholson on June 10, 2009 at 16:42:30 from (66.173.50.99):
In Reply to: Farmall C Still no Music posted by Eric Phipps on June 10, 2009 at 11:47:33:
Fill a pump type of oilcan with gasoline. Remove the plugs. Put two squirts of fuel in each hole. After squirting put the plug back in. Attach wires in correct order, and start it. If it starts for 5 seconds or so, it is a fuel delivery issue. If it does, the fuel is not getting to the air in the carb. Clogged passage, stuck shut float, or similar. JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
