Its not getting fuel. Did you check for a screen behind the tube fitting where your gas line is connected? It could be plugged. See if there's a full flow gas from the gas line to the carburetor. Hold a clean container beneath the gas line to catch the gas. Check that intake manifold to make sure its tight. Spray some of that carb cleaner around that intake while cranking over the engine. If it starts your intake manifold may need a new gasket. Your plug wires need to be in this firing order as you view the cap with No1. plug near the radiator.
If it still won't start bring No1 piston to TDC on the compression stroke. Then see where your rotor is pointing. If its not at the No1 plug tower your cam gear may have failed. While you're at TDC see if both valves are closed and if your timing marks are aligned. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
