Re: Farmall C Still no Music
Posted by farmerjohninpa on June 10, 2009 at 18:17:47 from (64.136.27.229):
In Reply to: Farmall C Still no Music posted by Eric Phipps on June 10, 2009 at 11:47:33:
just a stab in the dark here,,but when reassembling the carb did you remember to put back the "venturi" barrel that fits into the center of the throat,,on the split of the upper and lower half of the carb ?? and is it in right side up and not upside down, the gasket must also make a good seal around this item.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
