Re: Farmall M belly pump problems
Posted by glennster on June 10, 2009 at 19:14:16 from (24.14.63.246):
In Reply to: Farmall M belly pump problems posted by Jim in iowa on June 10, 2009 at 17:59:04:
first thing i'd do is put a hydraulic pressure gauge on and see what kind of pressure the pump is putting out. the early h and m pumps only put out maybe 6-800 psi. the later pumps were machined to a tighter tolerance and put out around 1000 psi. if you got pressures in this range, could be the cylinder on the plow is bad.
