So tonight I tried the hand-suction test on the carb intake. Sucks pretty good on cranking. Then I tried advice of trying starter fluid sprayed in intake. No firing. Couple backfires when I stopped cranking, but no good firing. Pulled each spark plug one at a time and laid on exhaust manifold and cranked. Good blue spark on every one of them. Then I tried jumpering around both the battery switch (left it on anyway) and the ballast resistor. Direct wire from battery pos to ignition coil positive. Still nothing. I tested the compression on each cylinder when I had the plugs out. They read 111, 114, 123 and 118 psi. What should they be?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
