Re: belly pump
Posted by rustyfarmall on June 11, 2009 at 05:19:19 from (209.152.78.140):
In Reply to: belly pump posted by john breeze on June 10, 2009 at 18:04:50:
john breeze said: (quoted from post at 18:04:50 06/10/09) belly pump won't lift a ford 460 motor and auto tranny. what is the lifting max weight?
Front end loader or boom pole on a 3 point? Either way there should not be a problem.
I know for a fact that an H equipped with a McCormick #31 loader will pick up a 1,500# bale of hay, and no, I do not recommend doing it.
