Re: Farmall M belly pump problems
Posted by Janicholson on June 11, 2009 at 09:48:31 from (66.173.50.85):
In Reply to: Farmall M belly pump problems posted by Jim in iowa on June 10, 2009 at 17:59:04:
The plow may need a third more pressure than the Farmall will make. If it is a three point plow, it was designed for a later tractor. Put a 1/3 larger diameter cylinder on the plow and it will raise well. JimN
