Re: f20 rod bearings
Posted by the Unforgiven on June 11, 2009 at 12:13:09 from (66.146.251.90):
In Reply to: f20 rod bearings posted by Eric Fox on June 10, 2009 at 16:58:58:
The rod bearings are babbit, but they are not poured, they are inserts. if you have shims left you are probably OK. I think the clearance is .002-.003 but I do not remember for sure. I have just taken a good pair of inserts out of a dead 20 if one looks bad, just make sure the crank has not been ground, they will have the size on the back of the insert.
