Re: Farmall H
Posted by Bob M on June 11, 2009 at 13:37:22 from (151.190.254.108):
In Reply to: Farmall H posted by K Ben on June 11, 2009 at 13:27:12:
What is it? It's OLD 40's era gear lube!
When I drained from the tranny/rear end of my '47 Minnie Mo U (what I suspect was the original factory fill) it came out jet black. The stuff was so stiff it would barely flow - took 2 days for it to drain completely.
For your H drain out what's in there, flush it with kerosene or diesel if it looks REALLY nasty inside then refill with fresh 80W/90.
Tip: Be prepared before you drain it! If the transmission is full you'll get about 7 gallons from it.
