Re: 856 throwout bearing lube
Posted by The tractor vet on June 11, 2009 at 16:37:47 from (99.167.208.210):
In Reply to: 856 throwout bearing lube posted by clilnt J on June 11, 2009 at 16:13:06:
Well drop the plate under the clutch housing and look up and see if yours has a fitting on it There are two 3/8th bolts holding the plate on so take your 9/16th wrench and remove it and look up my need a flashlite to see and no more the two pumps of grease
