Yes Hugh you are right, last weekend i was at a big tractor show in Yorkshire and JB2 met up with me. We had a good chat but i had to leave him as i was doing the commentry for the ring parade. About 450 tractors attended starting with the real old ones including 1897 Hornsby Ackroyd, 1903 Ivel and a 1912 Fairbanks Morse. Coming to the clutch problem take the cover off the bottom of the clutch housig. Now get some one to push the clutch pedal down to the bottom and you will see if the second stage of teh clutch is working. If the clutch pressure plate for the PTO clutch dose not move adjust the 3 bolt heads arround the outside of the PTO clutch pressure plate to get the PTO clutch to work. With your foot off the clutch the clearence under the adjusting bolt heads should be 080 th inch or the thickness of a Lucas ignition key. MJ
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
