Re: tubes for older IH corn planter
Posted by Janicholson on June 12, 2009 at 05:34:15 from (66.173.50.153):
In Reply to: tubes for older IH corn planter posted by charlie M on June 11, 2009 at 16:59:34:
If you are using it, and not showing it, I would use plastic expandable tubes from the big box store. They need to extend and compress when the planter is tripped, so measure the length difference, and make sure they will do the job. They may need to be attached at the bottom to be stretched downward, but that is OK. JimN
