I would say to start with fuel delivery. Remove the drain plug from the bottom of the carb and see if you got fuel. If it does then I would try the timing. It may be off by a couple of degrees. When you get it fired up with the ether (using a little bit) adjust your distributor either way until it pures like a kitten. May only need to rotate a quarter inch or so. Then wait and see if it keeps running. (Make sure you fuel is turned on, happened to me a few times)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
