Posted by Rootsy on June 12, 2009 at 10:45:16 from (24.247.111.162):
In Reply to: Farmall M overhaul posted by John Shipley on June 12, 2009 at 10:14:13:
going sleevless is going to require a trip to the machine shop, some pistons from one of the custom places and a few other items more commonly used by pullers in big inch engines...
If it is a 248 block you can go with 4" ID liners and get 264 CID.. if it's a 264 motor you can go to 4 1/8 overbore liners and get 281 CID...
Also have the option of doing a stroker assy...
All it takes is $$$ above and beyond a regular rebuild kit...
To run on E85 I would recommend the highest static CR you can get and eliminating all rubber in the fuel system. Carburetor will need to be recalibrated also. You can do a few things to get some power back out of the fuel swap but it isn't nearly as easy as playing with a SBC etc...
This post was edited by Rootsy at 10:49:38 06/12/09.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
