The problem may be the coil with the heavy contacts (cutout relay) it has a pull in winding with fine wires, and a heavy current winding with thick wires. If the pull in voltage is too high with the cap on, it will not pull in. Thus just barely weaken the spring on that relay so it pulls in a bit easier. The other coil adjusts the voltage when charging. If you have been making it tighter, that is not the answer. You may need to put it back to where it was. If when you loosen the other (cutout spring) too much, it will not cutout when the tractor is shut off, and the tractor will then discharge the battery rapidly into a smoking generator. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
