Re: Thermostat Super C
Posted by ScottyHOMEy on June 12, 2009 at 16:12:00 from (70.105.249.210):
In Reply to: Thermostat Super C posted by thumbanger on June 12, 2009 at 15:41:29:
I'm a ssuming you're taling about the wire clip that hold the stat down against the recess.
You can try CaseIHNHFord. Don't know if they still stock such a thing or not.
You can also fab one out of fairly hard steel wire. Needs to be about the gauge of a regular coat hanger, though I'd try to find some better steel wire than what goes into those. For shape, look in a parts catalog or the CaseIH online listings. It's a pretty simple arrangement.
