Re: wide or narrow on M
Posted by Andrew Z on June 13, 2009 at 05:10:18 from (64.148.11.55):
In Reply to: wide or narrow on M posted by pheel on June 13, 2009 at 03:43:24:
both the narrow and the wide fronts are equeally tippy or stable however you view it. the center of gravaity does not change much when you put a wide front on as apposed to the narrow. There was a set of test done back in the 50's that confirmed this. the best word of advice it to be safe and operate only on flat and firm grounds at low speeds. also add ballast to the back of the tractor, ie wheel weights of liquid or what ever you have this will help make the tractor more stable.
Andrew
