Posted by Bkpigs on June 13, 2009 at 05:35:49 from (75.132.238.145):
In Reply to: wide or narrow on M posted by pheel on June 13, 2009 at 03:43:24:
Andrew, what you said makes absolute sense. The reason being with a wide front the tractor is balanced on a pin. The only time the wide front would help is if the tractor would lean far enough for it to contact the axle. This usually is too late if the tractor is on a slope. But then again a narrow front's pivot point is at ground level giving the load more horizontal leverage. Guys, correct me if I am wrong but wouldn't it be easier on bearings and bushings with a narrow front since the weight is directed staight down instead of out and down. Just a thought.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
