Re: Farmall hyd. pump?
Posted by gpogpo on June 13, 2009 at 09:40:24 from (67.142.130.29):
In Reply to: Re: Farmall hyd. pump? posted by MIKE FRENCH on June 11, 2009 at 11:10:35:
Couple more questions Mike: Is the M&W pump the same as the optional Farmall pump? Do you have any idea on the output flow of the pump?...(to run a small loader). Can the pump be installed on a late model H using the original cam gear? Was it fairly easy to get your H retimed with the new pump? Thanks again. John
