specific name of this part for an H
Posted by Farmall Bob09 on June 13, 2009 at 17:02:18 from (75.220.173.93):
Hey guys after you pull the brake cover off and then the "wheel" where the break band touches, after that is the cast piece that is held on by 6 or so bolts then you take 2 of them and screw them back in to act as a puller. it also houses the bearing for the differential this cast piece is on both sides. mine is broke and i need to get another. What is the correct term for this piece? thanks in advance
