Re: Installing JOY STICK ON 706 I.H.
Posted by Armand Tatro on June 13, 2009 at 17:18:05 from (71.239.10.80):
In Reply to: Installing JOY STICK ON 706 I.H. posted by LOU from WI. on June 13, 2009 at 09:32:48:
Lou: Better not mount that cab until you have your hyd. plumbing figured out. With cable-controled valves the valves can be mounted anywheres on the tractor frame or loader frame that you want them. The only thing inside the cab should be the joystick assy. and the cables. With 55 in. of cable you should be ok on cable length. You may have to do your plumbing under the floorboard of the cab. I know how the Farmall 560D. is plumbed and I can get power-beyond by tapping into the pressure line as it comes out of the main pump. Where is the hyd. pump located on your tractor? Please let us know how this ends but be sure to figure out the plumbing before you mount the cab because this should be able to be accomplished with no hoses inside the cab. Armand
