Lou: You talk about 2 side remotes and one rear remote. Do you have one or two levers plus the 3point hitch controls now to the right side of your seat? If you hook a remote cylinder to each of the side ports and to the rear port(requires 3 cylinders to run this test) one lever will control the rear remote cylinder and the other lever should control the two side remote cylinders. If a one lever system all 3 remotes will be controlled. You can add a second valve body by taking pressure from one of the remotes and tying the approiate control back to supply pressure for the added valve assy. The best way to add a second valve assy. is th either split a pressure line between the pump and orignal equipmentvalve and hook the added valve in series or find a true power beyond port. The Tractor Vet. watches this forum and should have the best answers as He works on this series tractors. If he don't answer put a special post asking for him. Armand
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
