Re: pop in the trans
Posted by cazzhrdwd on June 13, 2009 at 18:29:05 from (96.234.155.61):
In Reply to: pop in the trans posted by cazzhrdwd on June 13, 2009 at 13:32:38:
It pops several times with each tire revolution. So When I go to tear it all down I will look the gears over. Your right about the water in the trans it ran out the level hole about as long as it ran out the bottom.
thanks guys
Cazz
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
