Posted by D Slater on June 13, 2009 at 18:50:53 from (72.65.152.152):
In Reply to: 300 Utility TA Removal posted by Dustin Bench on June 13, 2009 at 16:54:13:
Did you remove the complete t/a unit or just the transmission drive gear and shaft from rear of center housing? To put the 8 rollers in the ramp needs removed from transmission drive shaft bearing housing then install it and rollers on the end of t/a carrier housing then bolt it all back in the above housing. If you have the complete t/a removed the seal for outside t/a carrier should be easy to see how to remove. If you are meaning the seal on the input shaft of t/a, the 3 planet gears are supposed to be removed then the shaft slides out and seal is replaced. I have replaced that seal a few times without removing input shaft for a some just wanting a working unit on the cheap, but don't recomend it. A old planet gear shaft shortened or other shaft the same size is handy for installing or removing planet gears with needle bearings.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
