300u power steering ?
Posted by F2036 on June 13, 2009 at 18:51:50 from (205.188.116.73):
I have a 300u w/pwr str. Above the pwr str unit on the steering column there is a small pipe plug. It has been drilled out so it will act like a breather plug. From time to time oil will leak out of this plug making a mess on the battery.
I have replaced seals/o rings in the unit on the steering column and it still leaks oil fron this plug.
Have any of you guys had this happen before?
what did you do to fix it?
What would happen if I put a regular non vented plug in it place? My IH dealer's parts listing doesn"t even show this little plug.
Any thoughts or suggestions would be appreciated.
