Re: M Restore transmission/drive train question
Posted by Janicholson on June 14, 2009 at 15:27:14 from (66.173.50.121):
In Reply to: M Restore transmission/drive train question posted by IndiRon on June 14, 2009 at 15:15:37:
It is an open differential (no posi, or Lock system on it at all. If you turn one tire the other will turn backwards. (if the trans does not turn) The reality is that few situations on a farm tractor need the locked differential. If anything the wheel that did not turn may have a brake that is dragging a bit more than the other. Not to worry, you will probably go through them anyway. JimN
