They run pretty slow. 1750RPM (stamped into the ID plate under the serial number) wide open no load. This is called High Idle. If in doubt, rent a strobe tach, or a shaft tach. The strobe is shined on the front pulley and a knob is adjusted until the pulley appears to stop. The RPM is then read on a scale. A shaft tach is used on the PTO and 540RPM is the desired RPM at High Idle. I like Saginaw Brand 3 point hitches. X1 means it was designed to run on gasoline only. Using Unleaded regular is just fine. do not put in additives. No issues have been noted on these tractors, even with 10% ethanol. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
