Re: 450 Hydraulics are getting hot!
Posted by Chris NW Ind on June 14, 2009 at 17:26:21 from (64.136.26.235):
In Reply to: 450 Hydraulics are getting hot! posted by BigJohn450 on June 14, 2009 at 08:18:05:
My hot hydraulics was due to a deadheaded valve. More precisely, the selector was halfway between single- and double-acting. Fixed that with new roll pins for the detents. Then I replaced the regulator/priority valve assembly to get the PS workin. Replaced the main hyd. lines because the originals were leaking. Of course, this was all after I replaced the super-leaky pump. My 450 has good hydraulics with around $1200 worth of parts. Man, that is a depressing thought.
Chris B.
