Cub real axle
Posted by Dana Woolever on June 14, 2009 at 18:33:57 from (74.65.28.45):
I am brand new to cub restoration. Last winter I replaced the oil seals in the right side rear axle and re inserted it into the rear hub. At this time each wheel turns independently and if I remember correctly before I took the housing off when I turn one rear wheel the other turned.
Did I do something wrong when I re inserted? Is there a certain procedure to do this?
Thank you.
