Where's the H???
Posted by Eastsider on June 14, 2009 at 20:48:00 from (208.107.18.150):
See if you can spot the H! Every main part you need is there behind the tires and against the wall...hopefully the next time I get to work on it we will piece it back together! At least it is all apart and mostly cleaned up now!!!
third party image
