Re: M Hydraulics Question
Posted by mkirsch on June 15, 2009 at 05:40:02 from (64.80.108.56):
In Reply to: M Hydraulics Question posted by WI Dave on June 14, 2009 at 16:07:55:
Dave,
You could use a plow cylinder with two hoses. Just hook the top hose into the return line. It'll still be one way, but the cylinder will be venting into your tractor's belly pump.
OR
You could make your setup two-way pretty easily. Get an open center two-way hydraulic valve (around $100). Mount it somewhere convenient. Connect the hose coming out of the side of your M to the IN port. Connect the return hose to the OUT port. Get two more hoses. Run these from the work ports on the two-way valve to the couplers at the back of your tractor.
