Re: M Hydraulics Question
Posted by john d on June 15, 2009 at 07:07:45 from (69.130.165.67):
In Reply to: Re: M Hydraulics Question posted by WI Dave on June 14, 2009 at 18:22:51:
If the plow is set up to lower by gravity, you can operate it just fine with your single-acting setup. The second hose on the cylinder would not be needed if you put a vent plug in the other end of the cylinder. Your tractor will run a single-acting cylinder with or without that hose that runs to the fill pipe on your lift unit. Unless that hose is returning oil to the reservoir from a motor, you'll likely never need it.
