Re: Seized Engine Elixir
Posted by ET on June 15, 2009 at 09:10:17 from (134.179.104.135):
In Reply to: Seized Engine Elixir posted by F-Dean on June 14, 2009 at 19:27:10:
If it's seized because of a spun rod bearing you can dump all the snake oil you want it the engine and it won't do any good. Plan on taking the engine apart and fixing it right. Even if you get stuck pistons loose and the engine turning the rings are most likely to be stuck in the pistons.
