Re: oil for Farmall B
Posted by Rossputin on June 15, 2009 at 10:07:15 from (72.42.107.108):
In Reply to: Re: oil for Farmall B posted by Dave H (MI) on June 14, 2009 at 14:40:46:
Hi Dave,
So the blade is just attached to one handle and you have to be pretty strong to lift the thing! I'll probably use that for some snow plowing and some driveway grading.
Other than that, the tractor won't get lots of serious use. More just messing around. The bit of serious use it gets will probably be pulling a wagon to move wood around the property. We live on nearly 40 acres which is mostly forest and we cut trees occasionally for forest management purposes (and then need to move the wood so we can put it in the fireplace.)
It's mostly going to be a fun project.
