Re: international 1066
Posted by Jerry Walls on June 15, 2009 at 11:47:33 from (67.142.162.31):
In Reply to: international 1066 posted by jerry walls on June 14, 2009 at 14:41:51:
It slowly just quit pulling. No history. It always ran great.
Power steering works in both directions.
The T.A. seems to be working. When I move the lever there is a speed change.
I was moving hay, one in front and one in back, when I first noticed a problem. When I would start up a hill I would have to pull the T.A. back.
I had a guy look at it and drive it. He thought it was the M.C.V. I put a rebuilt one on.
When I was moving hay it would work for an hour and then it would quit pulling. After it sat overnight it would do it again the next day. After about ten days it will not even move a bale of hay.
